Old 12-29-2023, 05:16 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Default 1968-1969 GTO Hood and Fender Trim, What Screws, What You Do?
For the hood and small upper fender trim, people are using adhesive but is there a way to install using small body screws that already are on the car, possible stainless etc?
https://www.opgi.com/moldings/side-o...r-g240031.html
https://www.opgi.com/moldings/front-...e-g240920.html
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump, 12 Bolt, 3.73, 33 Spline
Old 12-29-2023, 07:03 PM
Scott Thelander's Avatar
I think the hood trim is a press fit
fender trims have 2 small phillips ea
and
have a spring steel shim style stamped flat metal nut on the back
Scott
