Old 01-12-2024, 06:14 PM
68hotbird 68hotbird is offline
Default WTB 78-81 G body engine clamshell mounts
Looking for a set of 78-81 g body Clamshell engine mounts for a Pontiac 301. Thanks, Paul.
Old 01-26-2024, 04:02 PM
T.D.Vick's Avatar
T.D.Vick T.D.Vick is offline
Are you looking for the block side or the frame side? The frame side can be purchased new. I may have a set of the block side if that’s what you’re looking for.
'80 Grand Lemans
Was 301 C.I. Will be bigger soon.
00 GTP NBM / Graphite, Stock
Sold Aug. 2011
70 GTO Black / Black TH400
460 CID, 542 FWHP, 580 FWTQ
(Sold, Fall '09)
04 GTO Black / Black M6
Back to bone stock and sold, fall '05.
Old 01-27-2024, 11:50 AM
Default Mounts needed
I am looking for the block side mounts. The frame mounts are readily available ne from Rock auto and others. Thanks, Paul.
Old 01-28-2024, 01:54 PM
tri.lllgto tri.lllgto is offline
Default motor mounts
Without me having to go look. do you happen to have the part numbers? Most but not all have the # stamped on them. I may be able to help you.
Old 02-09-2024, 06:58 PM
Default mounts found
thanks PY mounts have been found from a very nice member.
Old 02-09-2024, 08:40 PM
T.D.Vick's Avatar
I hope they go to good use!
'80 Grand Lemans
Sold Aug. 2011
(Sold, Fall '09)
Old 02-21-2024, 04:13 PM
MarkS57's Avatar
MarkS57 MarkS57 is online now
Came across this recently. Seems those brackets may not be as rare as once believed? Used on several cars but not for the F bodies.
ID:	629130   Click image for larger version
65 Tempest, 400, TH400
86 Fiero SE 2.8
Old 02-21-2024, 05:14 PM
T.D.Vick's Avatar
I also pulled a set from a 78-80 Buick Regal that had a 301 in it. I don’t know how common those are though.
'80 Grand Lemans
Sold Aug. 2011
(Sold, Fall '09)
Old 02-21-2024, 07:16 PM
T.D.Vick's Avatar
'80 Grand Lemans
Sold Aug. 2011
(Sold, Fall '09)
