400 small register crank strength
Getting ready to build a 78' 400 for a customer and it has the lighter, thin counterweight, small crank register crank in it. Has anyone had any issues with these cranks in a performance application? The engine will have out of the box KRE D port heads and a hyd. flat tappet cam, probably be around 390-400 Hp range. I have other earlier N cranks but would like to stick with this crank since it's std/std., if it's strong enough.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
I would only have a start for concern once the 475 to 500 hp level was being reached.
The core of the crank where it counts in terms of strength is still the same, as in from a main or rod journal to the crank cheek. Plus with a 3.750” stroke the rod fillets are seeing 12.5% less G force then if the motor was a 455.
Consider most Chevy motors have a small register too.
Great option... A lot of Super Stock's run these.
Thanks Paul! I thought I had heard that a while back too. I'm going to use it.
The Following User Says Thank You to Gary H For This Useful Post: | ||
Wasn't worried about the small register per se. I was only mentioning to help identify which crank I was referring to that had the narrow counterweights. I've decided to use it.
Gotcha!
Like Paul said some of the "Stocker/SS folks" run them. Stick or auto?
Hi Skip, I know of a few auto trans cars. It's a nice way to remove several pounds of rotating weight. Every so often I come across a light weight casting with a large flywheel register.... Those are the hot set up.
The Following User Says Thank You to PAUL K For This Useful Post: | ||
What the part number on the crank? Just curious, I tore down two later 400s not too long ago and both crank had a 350 part number on it
78 T/A 4SPEED, Original paint, match #’s, stock original bottom end, milled 6x-4s, HE268H cam,17058263 Q-jet/ 72 jets, CH secondary rods, RA Manifolds, poly body bushings, Moroso SFCs,mine since ‘99. 79 Parisienne just got it 77 t/a sold 85 Monte Carlo SS sold 83 Mustang GT sold |
I know Bill Rink, (RIP) used the small register, light cranks in his stock and SS 74 GTO. That was a 350 inch engine however. He ran it hard and at high RPM's. 10.60's. Not aware of him ever breaking one.
The Following User Says Thank You to mgarblik For This Useful Post: | ||
