Old 01-28-2024, 10:06 AM
reacp911 reacp911 is offline
Default 400 block main cap dimensions
Hi all
I'm still designing my custom road race oil pan, but I still haven't had the courage to pull the motor
Could someone measure the main cap dimension from block to windage tray mounting bosses if you have a motor open or a spare cap?
I need to determine the gap between the stock oil pan and the windage tray to determine how much gap there is for oil return. If it's less than say 3/8 I may need to use the canton pan I'm currently running because its deeper at the front of the motor.
Thx
Old 01-28-2024, 01:55 PM
firechickenman's Avatar
firechickenman firechickenman is offline
I get right at 3.015" on a 455 and IAIIA caps. 400 should be the same.
Greg Weigart
IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/6.21@110.47/9.77@137.08
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
Old 01-28-2024, 03:44 PM
Great! thanks
so the windage tray is 1.3 inches, and the pan is 4.5 so it leaves a clearance of 0.2 inches. I wonder how much of an impediment this is to oil returning to the pickup?
