Old 01-29-2024, 01:29 AM
1950Mercury 1950Mercury is offline
Default 1966 Pontiac GTO under dash wiring
Trying to decipher what I have. Working on 66 GTO 4 speed console car none A/C rally gauges. The under dash wiring is M&H.. Looking at there website it seems they do not offer a harness for a 4 speed car with gauge package. Closest is automatic w/gauges. Is there one offered for 4 speed console GTO's with gauges? On the left side of the harness there are 3 pairs of wires with 2 wire each and a plug at the end. 2 purple 2 green and 2 orange. I figured the purple are neutral start. Although I don't 66 manual 4 speed had a neutral start. Anyone know what the other 2 pairs are for? Also the diagram refers to a master switch and a master relay.. Where are they located and what do they do? Is that for A/C cars only? I appreciate any input.
ID:	627392   Click image for larger version
Name:	1966 GTO electric diagram.jpg
The Following User Says Thank You to 1950Mercury For This Useful Post:
Old 01-29-2024, 11:40 AM
GoGoat GoGoat is offline
The green pair would go to reverse switch . The orange pair would go to the downshift switch if it is an A/T. I belive this is correct and I think you are correct on the master switch and relay.
Old 01-29-2024, 11:47 AM
The purple pair would be the start circuit. On your car there might be a switch on the clutch pedal .
Old 01-30-2024, 08:43 AM
importsmasher's Avatar
importsmasher importsmasher is offline
As stated, the purple ones should be the starting circuit. No clutch switch until 69; the factory put a jumper on that plug for manual transmission cars.
Importsmasher
Scott Baggiore
66 GTO convertible 389/4 speed (parents bought new)
73 Firebird Formula 400/4 speed
74 GTO 455/4 speed
74 Grand Am
The Following User Says Thank You to importsmasher For This Useful Post:
Old 01-30-2024, 03:36 PM
Jonsie Jonsie is offline
while you've got the car apart it might be a great time to hook-up an underdash kill switch using those purple leads
Old 01-30-2024, 07:27 PM
Jeff Hamlin's Avatar
As mentioned the NS wires would have a jumper installed on MT cars.
Nothing more than a small C-type connector with rubberized insulation on the outward portion.
This would be plugged into the plastic connector to complete the circuit.
Factory Jumper Shown;
Name:	NSS JUMPER.jpg
ID:	627575   Click image for larger version
Name:	NSS JUMPER 1B.jpg
ID:	627576   Click image for larger version
Name:	NSS JUMPER 1A.jpg
