Old 01-29-2024, 06:09 PM
dv657172 dv657172 is offline
Default Fan & Water Pump switch location
100% drag car
68 Pontiac 400 block with #16 heads
Looking for good spot to install a switch in the block to signal fan and water pump to come on
Currently I am using manual switches so I can continue to run them even after car is shut off (car originally raced in South FL). Would like to have them also come on automatically so I dont forget to turn them on. Have the wiring figured out I think, just need a spot for the switch
Have a Torker II intake manifold with front DS fitting at water crossover used for under dash temp guage
Griffin radiator with only fitting at bottom DS used for drain
Thanks for any ideas
