Old 01-31-2024, 11:59 PM
Ramairnacho Ramairnacho is offline
Default 1970 glove box
I bought me a replacement original glove box door for my 1970 formula. Question. . Do they repop the glove box inner sticker and is the glove box arm the same as 71-81? I don't have the key and don't remember if it's same as door key and or trunk. Maybe someone can teach me. I plan on getting a dash restored and have a nos 71-81 door that I might use and just put a repop sticker on. It or make a sticker.
ID:	627661   Click image for larger version
Old 02-01-2024, 07:59 AM
cnc's Avatar
cnc cnc is offline
There is a thread on this forum someone is reproducing stickers, but can't locate it at this moment he is doing all sorts ...
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
The Following User Says Thank You to cnc For This Useful Post:
Old 02-01-2024, 09:37 AM
MDSHARK81 MDSHARK81 is offline
On the keys your door and ignition used the same key(square), while the trunk and glove box used the other(round). It was like this until 1973 I believe that is when they switched to the commonly known GM pattern of Square key ignition only and round all others.
You can consult your owners manual if you still have it.
The Following User Says Thank You to MDSHARK81 For This Useful Post:
Old 02-01-2024, 11:32 AM
Thaks
Old 02-01-2024, 07:00 PM
cnc's Avatar
cnc cnc is offline
https://forums.maxperformanceinc.com...ghlight=Decals
Go through the post and see what he has been doing I recall something a joust glove box decals but not sure exactly what it included
Old 02-02-2024, 02:57 AM
Red80TA Red80TA is offline
Why would you put a NOS 71-81 door on it? Unless you already need the original door for another 1970 and don't have an extra, in which case you'd say that.
Old 02-02-2024, 02:23 PM
Default 1970 dash
My original dash broke ,my replacement 71 dash broke, when I get a restored or new reproduction dash not sure how grain will match or contrast. Since the 72-81 dash texture all same it might be a better candidate. That's why.
Old 02-02-2024, 06:05 PM
unruhjonny's Avatar
I do not believe that the correct 'RM' glove box sticker is currently made.
There is a decent 'RN' decal that was supposed to only be used on Trans Am's, but has been found on original Formulas.
You actually posted in THIS thread here that I made on the subject.
HERE is the 'better decals' thread - I have been hoping (but not pushing for) a correct RM tire decal for my car - but unless that happens, the RN decal I have will do.
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
