Old 02-08-2024, 01:00 PM
Tom63LeMans's Avatar
Tom63LeMans Tom63LeMans is offline
Default Lifter bore braces
I'm prepping a 400 block for my gasser and looking at lifter bore braces. I used the SD Perf Mega Brace in my current engine and would use the same if they were available.
Looking for suggestions from those that have used other braces. I'm running a hydraulic roller currently with Crower mechanical lifters. It's small enough that a brace shouldn't be required but eliminates one of the things that keep me up at night.
Thanks.
Tom
Tom
1963 Lemans -428 +.030, SD Perf KRE heads, turbo 350, 9" Ford 3:90, 11.01@121
1956 Chieftain gasser, 461 stroked 400, SD Perf ported E-heads, turbo 400, Dana 3:70 10.40@125
Old 02-08-2024, 01:22 PM
misterp266's Avatar
Here’s a link to Kristinn’s Big Brace.
http://forums.maxperformanceinc.com/....php?t=836832/
" Darksiders Rule "
Old 02-08-2024, 01:42 PM
grandam1979 grandam1979 is offline
Butler doesn’t show them not available?
Old 02-08-2024, 03:30 PM
steve25 steve25 is offline
So does Crower say it’s safe to use there solid roller lifters on a hydro cam that does not have the needed ramps to take up lash?
Old 02-08-2024, 03:35 PM
Jay S's Avatar
Jay S Jay S is offline
Both KRE and Bulter’s offer lifter braces. Butler’s is a SDP brace.
Old 02-08-2024, 04:17 PM
Stan Weiss's Avatar
Steve,
The ramp design is what determines what the lash needs to be. Hydraulic cams do have ramps, they are just very short / small and so that is why the need for a very small lash when running solids on a hydraulic cam. Back in the late '60s I ran an Engle solid roller cam in a SBC where Engle wanted the lash set at 0.012" I and 0.014" E.
Stan
Pontiac Pump Gas List
Old 02-08-2024, 05:34 PM
I called them today and they do not have any. They said they expect some soon but according to Dave Bisshop’s last update on his webpage they are not operating yet
Tom
Old 02-08-2024, 06:35 PM
Those look great but were designed around 48**** 70s blocks. Mine is a '67 block.
Tom
Old 02-08-2024, 06:39 PM
This setup was recommended to me by Dave at SD. I've been running his Old Faithful cam in my Lemans with Hippo lifters setting lash at .004-.006 cold with no issues for 7 years. Running the same on my '56 with a custom grind from him.
Tom
The Following User Says Thank You to Tom63LeMans For This Useful Post:
Old 02-08-2024, 07:30 PM
1967 lifter bore area is different than 68 up ?
Old 02-08-2024, 07:40 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
In my experience, any brace needs to be custom fit to the lifter bores. I have the SD brace installed on my 474, I had to grind the brace to fit snug on the lifter bores. This is due to core shift amount blocks. So the one designed for a 67 block, would need the same treatment to fit snug. Nothing unusual I think
Old 02-08-2024, 08:39 PM
From the person that makes them. They did post the were working on a brace for the earlier blocks but last update was a year ago. I’ll try to find out.
“Originally Posted by catc
View Post
Curious seeing how you state these are designed for the 988 block , what are your thoughts on a 9779914 block..would there be that much difference?
The 48xxxx castings have different contours/shape compared to the earlier 97xxxxx blocks. I’m planing on doing braces for the 97xxxxx blocks but have not had time yet.
It would be too much hack and triple amount of epoxy to put the current ones in the early blocks
Kris.”
Tom
Old 02-08-2024, 10:55 PM
BILL BOWMAN1's Avatar
I have used the KRE brace with solid roller.. 270ish @ .050 .700
50+ 9 second runs without issue.
The Following User Says Thank You to BILL BOWMAN1 For This Useful Post:
Old 02-10-2024, 02:52 PM
blueghoast's Avatar
X2
All the braces have to be fitted. I had to with all the one's I used even the
billet brace.
GT
Old 02-10-2024, 06:57 PM
Originally Posted by blueghoast View Post
X2
billet brace.
GT
I realize that they all need some work to fit. I had to do a decent amount to my Mega brace. But when the manufacturer recommends against using theirs, I’ll look for a different option.
Tom
Old 02-15-2024, 05:55 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
Thanks for the interest guys ... I haven't really put any weight behind these since I don't have my own cnc equipment ... yet
... and most certainly didn't want to take advantage of Sd performance misfortunes.
Yes the #97XXX version is in the works ... along with doing these in steel as it would be the superior solution according to my findings, bonding and movement.
Thanks,
Kris
*** THE BIG BRACE is here ***
The Following User Says Thank You to RUDOLFSSON For This Useful Post:
Old 02-23-2024, 03:20 PM
VCho455's Avatar
VCho455 VCho455 is offline
I talked with Dave (SD Performance) yesterday (2/22/24) and he had shipped the standard braces a while back to Butler and they should be in stock.
Dave also stated that he had just that day shipped Deluxe braces to Butler so theoretically they should be available late next week.
Old 02-23-2024, 03:40 PM
Butler said they had some coming. I ordered 2 sets and they were delivered this week.
Tom
