Old 02-08-2024, 07:13 PM
ta man ta man is offline
Default Northwind vs Torker 2
Has anyone replaced a Torker 2 with a Northwind intake? Any dyno tests or et improvement?
Old 02-08-2024, 07:15 PM
i82much's Avatar
i82much i82much is offline
https://www.sdperformance.com/newsStory.php?newsID=53
in case you haven't already seen this
Old 02-08-2024, 07:49 PM
Thumbs up
Now that looks quite promising and well worth trying the Northwind.
Quick question - are you currently running the original 8.5” 10-bolt rear end in your T/A ? And if so what axles/spline count and which limited slip differential are you using ? Thanks!
Old 02-08-2024, 08:10 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
The Torker II runners keeping a good cross section way up the runners is difficult if you have a high flowing head, besides needing weld at the top of the port for 320 cfm E heads. The Northwind has good runner size and I would guess even a bigger plenum than a Victor. T2 plenum measures larger than a Victor plenum also.
Skip Fix
Old 02-08-2024, 08:24 PM
Gach's Avatar
Gach Gach is offline
My buddy Ed, made 810 hp with Northwind, but its a solid roller. 535 ci. To fit everything under the hood. Thats with 1” spacer.
I was a little surprised, of course it made more with the Victor I think around 835 hp. But its a street car on pump gas.
Reading SD Perfromance testing where he says [quote ] With a CNC port matched Victor and CNC plenum (previous testing showed the modified plenum was worth 20-25hp) [quote ] i’m laughing because when I said my unport Victor vs me fully ported Gabby intake made 25-30 more hp over the unported Victor. It was question? LOL remember though my Victor was cut in haft and a big incase in platinum area as well as runners size. But also Pro System carb 1150 cfm.
Old 02-08-2024, 08:34 PM
Gach's Avatar
My question would be whats your cubic inches? Just remember SD example is with a 535 ci. Which is dying for more intake if your in the 462 ci range you might not see same results. Just keep that in mind, I mean other then a back to back swap at the strip or dyno which probably isn’t worth the money and aggravation. Because other thing may come into play. Like jetting….. maybe
Old 02-08-2024, 09:08 PM
30 spline Dutchman axles Eaton diff..axles tig welded to center section, Moser diff cover with carrier bearing supports
The Following User Says Thank You to ta man For This Useful Post:
Old 02-08-2024, 09:09 PM
466..Swap at the track wouldn't be too bad. Water crossover stays on engine..on the other hand I have a pretty good grip on the tune on what it should run.
Old 02-08-2024, 09:10 PM
Thanks..I asked Dave Bisschop a few weeks ago what his thoughts were..he said it is worth a try.
Old 02-08-2024, 09:19 PM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
I'm kinda surprised there aren't more results and data out there for a 15 year-old manifold.
Old 02-08-2024, 09:22 PM
Gach's Avatar
I guess you never know until you give it a shot. Be interesting for sure.
Old 02-09-2024, 12:56 AM
RocktimusPryme's Avatar
Maybe Im misunderstanding the intake heights, but I don't see how with the given heights we have in the "Intake Height" Thread that the Northwind fits under stock hoods, especially with a 1" spacer.
I have a lightly ported RPM, and have been considering a move to a single plane. The RPM with no spacer still requires a pretty substantial drop base.
Is the Northwind notably shorter than the RPM?
It seems to always workout that if you don't run a spacer on a single plane, you are giving up power, so I don't want to bother if I cant run a spacer. I had pretty much told myself if I wanted to do it I was going to be swapping hoods.
Old 02-09-2024, 01:26 AM
Gach's Avatar
There is definitely a problem with the Northwind fitting under the hood. Ed told me, he doesn’t think it’ll fit with a 1” spacer, with out doing some hood modifications in his 74 Firebird. As it was his Victor was cut down when he was running the high port heads he’s sense gone with E-heads and Northwind, but as far as I know it won’t fit a 1” spacer.
Old 02-09-2024, 06:55 AM
steve25 steve25 is offline
Since any Plenum acts like a reservoir the bigger the cid the greater that need is .
Old 02-09-2024, 09:25 AM
Steve C. Steve C. is online now
If interested....
4-inch stroke combo with 310 cfm KRE heads, Comp solid roller cam with 248 degrees intake duration.
Dyno tested with a Northwind intake using 2.300" tall ports & 4150 Holley carb.
576 hp at 6100 rpm on an engine dyno.
Northwind overall height and port exit dimensions discussed here:
https://forums.maxperformanceinc.com...ight=Northwind
Old information here:
Old 02-09-2024, 09:42 AM
Half-Inch Stud's Avatar
5-7 isolation will reveal the better manifold.
2-1 isolation too.
Old 02-09-2024, 09:47 AM
Johnny406's Avatar
Johnny406 Johnny406 is offline
My RPM limited HFT cammed car picked up going from the Northwind to the TKII. It picked up even more going from the TKII to the ported HSD. I would bet the opposite would happen with your combo and that you will pick up .2+
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 02-09-2024, 09:49 AM
i82much's Avatar
Butler says the Northwind is 1.25 inches shorter than a Victor:
https://butlerperformance.com/i-3000...tegory:1291427
Summit says a Victor is 7.7 inches:
https://www.summitracing.com/parts/e...7/make/pontiac
And an RPM is 7.45 inches:
https://www.summitracing.com/parts/e...6/make/pontiac
So a Northwind should be about 7.7 - 1.25 == 6.45 inches. If you can use an RPM without a spacer, you should be able to use a Northwind with one.
Old 02-09-2024, 10:04 AM
Again, old information....
Northwind intake manifold height vs Torker 2
https://forums.maxperformanceinc.com...d.php?t=851330
Old 02-09-2024, 10:13 AM
i82much's Avatar
how does a smaller engine running at a higher RPM react differently to plenum size than a bigger engine at a lower RPM?
If we have two 600 HP engines, say a 455 peaking at 6000 RPM and a 535 peaking at 5400 RPM, does the 535 see a benefit going to a bigger plenum that the 455 does not see? And if so, why?
