Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 02-13-2024, 01:48 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Default Professionally built hot rod Q-jet
Professionally built hot rod Q-jet. This was built from a low mileage TA core by Joe Scott. It was built for a 550 hp iron head combo and performed flawlessly. It may need to be freshened as it's been sitting for many years since used last. Everything appears to be in good condition and works as should. The choke assembly has been removed but the plate is still in place and locked open. The secondary jet orifices were replaced with larger screw jets but still uses metering rods. Primary throttle shaft bushings have been installed. This carburetor ran great on the application it was built for, but may need some fine tuning for another combination. This carb would also be legal for Super Stock.
Carb # 17057274
Date 1896 AR
$350 plus shipping
ID:	628546   Click image for larger version
ID:	628547   Click image for larger version
ID:	628548   Click image for larger version
Go fast, see Elvis!
Old 02-13-2024, 06:25 PM
Tim Corcoran's Avatar
750 or 800?
Tim Corcoran
Old 02-13-2024, 06:30 PM
PAUL K's Avatar
800 cfm unit
Go fast, see Elvis!
Old 03-11-2024, 07:15 PM
PAUL K's Avatar
Bump
Go fast, see Elvis!
