Old 02-24-2024, 12:35 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default OEM battery tray
I was viewing another thread on battery trays for the RH side of the car which made me think of the trays for the LH V-8 side of cars.
I’m not sure what battery tray the ‘64 GTO came with from the factory, but the 65-67 trays had two styles.
1965 and 66 V-8 trays had two flat tabs with a slight outward bend at the top of those tabs.
The 1967 tray had tabs with a strong inward bend that locked into a molded groove on the bottom of the battery.
Below are a couple samples I have showing the 1965-66 battery tray.
A must for an Unrestored Survivor 65-66.
ID:	629249   Click image for larger version
ID:	629250   Click image for larger version
ID:	629251   Click image for larger version
ID:	629252   Click image for larger version
Old 02-24-2024, 12:40 AM
60sstuff's Avatar
This is the tray that superseded the 65-66 style.
Typical found on all the 1967 V-8 Tempest Series cars.
Different tabs.
ID:	629254   Click image for larger version
The Following User Says Thank You to 60sstuff For This Useful Post:
