Old 03-29-2024, 06:27 AM
etennett etennett is offline
Default Slight intake manifold vacuum leak
Don’t really feel like tearing it out an and putting in a new gasket right now. Is there a good rtv or a sealer I can apply where the leak is as a temporary fix? The leak is where the manifold bolts to the head just below the valve cover.
eric
Old 03-29-2024, 07:30 AM
grivera's Avatar
grivera grivera is offline
Try Ultra Black and send it!
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
The Following User Says Thank You to grivera For This Useful Post:
