Although everything you see here was taken from a 4 speed 70 Formula that had the original carb, open face alternator, distributor, 70 only p/s pump brackets pulley, the number on those pulleys suggest they are for a 71, according to all the research I've done.
So it is: 481037 YA crankshaft pulley, two groove (no a/c), reinforcement, and correct four bolts. 481039 XF water pump pulley, two groove (no a/c) 3947132 fan spacer (1 15/16" long) with correct four bolts. everything you see here for $100 plus $20 flat rate shipping anywhere in the lower 48 and Canada. |
