Old 04-05-2024, 10:44 AM
1950Mercury 1950Mercury is offline
Default 3 deuce jetting
Can someone tell me what is the most common primary carb jetting on a 66 GTO 3duece setup? 389 engine mild cam 4 speed.
Old 04-05-2024, 03:19 PM
If this helps you factory jetting for the center carb was #.063 .
Kenth's Avatar
Kenth Kenth is offline
1966 389/421 M/T center carb 7026075 uses 60° #62 jets, 7008662.
1966 389 M/T w/A.I.R. center carb 7036175 uses 60° #61 jets, 7008661.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 04-05-2024, 03:21 PM
Kenth's Avatar
Source on that?
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 04-06-2024, 11:47 AM
Cammer-6 Cammer-6 is offline
OP there is a separate topic just for tripowers
might get you more exposure
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 04-06-2024, 11:50 AM
My post came directly from the 1969 Pontiac parts book.
Old 04-06-2024, 03:57 PM
Kenth's Avatar
Thatīs odd, none of my books, 1970 Pontiac Master Parts Catalog or Delco Parts&Service manual #9 shows #63 jets for any 1966 Tri-Power center carb?
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
