Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 04-07-2024, 06:29 PM
Apache Warrior's Avatar
Apache Warrior Apache Warrior is offline
Default F/S Ross Pistons / TS Rings / Ross Spirolox
Chicagoland area - 60047 will be the shipping zip code.
Qty (10) Ross pistons originally sourced through Butler Performance.
New.
Were installed in a motor but never run. Engine was fully assembled/loaded and turned over by hand many times.
Job Card # 121277.
4.310 bore - net diameter 4.305.
Compression height 1.430.
Were ordered to be used with a 6.8 rod, a .990 pin (2.930 and double spirolox), 10.230 deck height, and a 4” stroke.
2cc dome (.115).
Ring grooves .0640 / .0640 / .1880.
Ring lands .165 / .155 / .080
Intake V.P. diameter 2.300 Depth .280
Exhaust V.P. diameter 1.900 Depth .250
Original rings removed from pistons and bagged. Included with pistons. Never run.
TS classic file-to-fit # CR9160 65. 1/16 1/16 3/16.
New TS classic file-to-fit rings included (new in box). TS # CR9160 65 sourced through Butler Performance.
New Ross Spirolox included (new in bag). Ross # 4004-E (Qty 33) sourced through Butler Performance.
Have original Ross piston box.
All pistons were recently weighed on a new gram scale and are marked and bagged.
Piston pins NOT included.
Pics attached.
$700 for all items. Money Order/Personal Check preferred payment. Will ship as soon as payment is processed.
Buyer to pay freight in lower 48.
ID:	631740   Click image for larger version
ID:	631741   Click image for larger version
ID:	631742   Click image for larger version
ID:	631743   Click image for larger version
