Tri-Power Tech 57-66 Tri-Power Talk
Old 04-13-2024, 09:33 PM
bill ryder's Avatar
bill ryder bill ryder is offline
Default 65-66 RamAir question
I know this will make some wonder, what the H***, but I was asked this question today.
How is a ramair pan correctly installed?? I replied "loosen the base nuts if necessary, set the pan on the 3 carbs, set the air cleaners on the pan over the studs, set the chrome lids on the studs, and wing nut them down".
The guy says he bought the pan over the counter in 1968 and it came with a complete std. 3X2 filter set up. He said " if it came with these parts, they must be needed. Should I put the bases under the pan or inside the pan"? I had no answer.
Your thoughts please!!!
"Bill"!
Old 04-13-2024, 10:53 PM
wolf's Avatar
wolf wolf is offline
The pan replaces the bases,
Old 04-13-2024, 11:11 PM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
The Wolf has howled (spoken) and is correct.
Old 04-14-2024, 08:59 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
As Wolf 🐺 said, no bases needed.
The three dimples on the inside of the RA pan at each carb hole support the bottom of the filter.
ID:	632084   Click image for larger version
Old 04-15-2024, 04:01 AM
Kenth's Avatar
Kenth Kenth is offline
The ACDelco A220C replacement paper filters will rest above the dimples.
If you have the original style foam filters with the original screens, the screens will rest on the dimples.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
