Old 05-03-2024, 08:28 PM
blue67gtoragtop's Avatar
blue67gtoragtop blue67gtoragtop is offline
Default 67 GTO 1/4 glass vertical chrome strip removal/replacement
What is the best way to remove and install the chrome strips on the leading edge of the quarter windows in a 67 GTO convertible?
Old 06-06-2024, 01:45 PM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
Default Remove with a rubber hammer
remove with a rubber hammer. Place the glass on a padded surface, use a wood block to catch the edge of the trim. it is pressed on and has a black felt rubber lining that holds it in place. Tap it off and be careful not the break the glass. Only tap against the trim. you will see it move. start on the lower end and work your way up.
Install the reverse way using urethane for window installs. Run a thick bead in the trim, press it on with your hands and add two strips of masking tap to hold it on until it dries. do not clean the urethane off until it dries. you will create a big mess.
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
