Old 05-24-2024, 11:21 AM
Default Edelbrock D-ports: what lifters, pushrods and rockers
I took the round port 72cc Edelbrock heads off of my spare engine and sold them. I'm going with 87cc D-port Edelbrock heads, with a fairly tame Summit 2801 cam. I have to maintain a low profile to fit the valve covers under the AC blower under the hood.
Can I just order stock lifters, pushrods and rockers? I was hoping to just get some stock iron heads, but rebuilt ones cost the same or more than the Edelbrocks. It would be nice if I could just order this stuff from Rock Auto.
Old 05-24-2024, 08:09 PM
indymanjoe's Avatar
well imho stock wont cut it. My stock d-port 96's pushrods are 8.750 my 87 round port edelbrocks came in at 9.050 hydraulic roller lifters and crower rockers. same parts other than the pushrods which im glad i did the time to get it right. better advice will be coming soon for ya i hope.
Old 05-24-2024, 09:53 PM
tooski tooski is offline
Default Pushrod length
I have KRE's. Since they and Edelbrocks require the same aftermarket head bolts I'm going to go out on a limb and say the push rod length requirement would be the same or similar. I have an HFT cam with stock lifters and pushrods. 1.65 full roller rocker arms. Under stock rocker arm/valve covers. This is the pattern across the valve tip.
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 05-24-2024, 10:31 PM
grivera's Avatar
grivera grivera is offline
I suggest you buy an adjustable pushrod and measure- this isn’t a step where you should take a short cut.
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'69 LeMans Vert, 350, #47 heads: work in progress
The Following 2 Users Say Thank You to grivera For This Useful Post:
