Old 05-24-2024, 04:03 PM
Tim Corcoran's Avatar
Default Dip stick tube in the block
I have a new dip stick tube I got from Butler. I'm getting ready to install it into the block. I'm pretty sure it installs from the bottom but my question is how do you know how far to insert it? Is there a measurement? Picture?
Tim Corcoran
Old 05-24-2024, 05:03 PM
steve25 steve25 is offline
You drive it in until the end of the tube meets the inner wall of the block.
With a file or a bench grinder taper the leading edge of the tube and use a swipe of sealant as a lube.
Old 05-24-2024, 07:51 PM
grandam1979 grandam1979 is offline
Put it in before you assemble the shortblock it will make life much easier.
The Following User Says Thank You to grandam1979 For This Useful Post:
Old 05-26-2024, 10:56 PM
Thanks for the advice, but I did already have the short block assembled. All I had to do is remove the number 3 main cap to get the clearance needed and tapped it right on in.
Name:	Dip stick 1.jpg
Tim Corcoran
Old 05-27-2024, 06:43 AM
Looks like you have it perfect !
