Old 05-25-2024, 11:51 AM
Tim Corcoran's Avatar
Default Questio about engine bearings
I am wondering why do fully grooved main bearings have an oil feed hole on both bearing halves? I don't see a reason for the hole in the bearing on the cap side?
Tim Corcoran
Old 05-25-2024, 01:12 PM
steve25 steve25 is offline
Likely because the manufacturer would spend more time when stopping the production line to remove a the bearing before drilling the hole then the time it takes to drill the hole.
Old 05-26-2024, 10:07 AM
Pontiac Performance Author
So that you can' t screw up and block the oil passage.
The Following 3 Users Say Thank You to KEN CROCIE For This Useful Post:
