Old 05-25-2024, 01:01 PM
triathlonx13's Avatar
Default TH400 transmission help
Any transmission & CAM guys out there that can help with information? Will my 455 with this cam give me enough vacuum to properly work with my auto valve body TH400?
Old 05-25-2024, 02:46 PM
Dragncar Dragncar is offline
I would say yes.
I ran a larger cam than that and the T400 I built shifted fine in D.
The Following User Says Thank You to Dragncar For This Useful Post:
Old 05-25-2024, 03:51 PM
steve25 steve25 is offline
What heads are you running?
The size of the chamber effects the level of idle vacuum you pull also.
I would also hope that with a cam of those specs that your running at least 9.5 to 1.?
Old 05-26-2024, 08:17 AM
Thanks guys.
Yes, 9.5:1
Here are the head specs.
ID:	634305   Click image for larger version
Old 05-26-2024, 08:36 AM
Formulas Formulas is offline
The TH400 vacuum sensing / operated light throttle upshifts with the stock modulator are pretty care free but after your built and driving and want a different experience you can opt for the aftermarket adjustable unit to tune light throttle in town stop light to stop light shift points, because there is little shaft speed
Right foot down to the floor shift points are controlled by the governor by changing weights and springs, because there is little vacuum
If your not at the table you're on the menu
The Following User Says Thank You to Formulas For This Useful Post:
Old 05-26-2024, 04:19 PM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
Yes, it should be no problem at all!
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
The Following User Says Thank You to Jim Moshier For This Useful Post:
