Old 05-27-2024, 12:13 AM
Ramairnacho Ramairnacho is offline
Default Front grills
so I damaged my driver's front grill as a boy long ago and was looking through my extras and noticed all basically the same except 1 right side grill. It didn't have rivets holding the outer trim to the main grill and had Abs burn stamped in it. looks same other than that detail ,but my originals are riveted on. Is this an aftermarket ot 71 maybe? The 1st pic is my original and second phase no rivet on the trim to attach to body also it has abs stamped on it. I have about 8 grills and this is only 1 that has no rivets holding chrome tri..to msin body. I want to clean up and paint them correct color and noticed this .Any advise?
ID:	634340   Click image for larger version
Old 05-27-2024, 12:17 AM
Default front grills
I plan on running these or removing tri.m and putting on my original
Old 05-27-2024, 12:18 AM
I plan on running these or removing trim and putting on my original. Just curious why I got 1 odd ball non riveted one Following is a picture showi.g no.hole or support rivet.
Old 05-27-2024, 12:26 PM
72projectbird's Avatar
Hmmm
The grills on my 71 aren't riveted either
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 05-27-2024, 02:14 PM
are they original? are riveted 1 year only part?
Old 05-27-2024, 03:16 PM
unruhjonny's Avatar
I believe that often not all the mounting tabs were used.
1970 Formula 400
Old 05-27-2024, 07:00 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
Are you sure that what you are seeing is a metal rivet? Does a magnet stick to it?
My grills look like they had a peg like protrusion on the tab that stuck into the hole on the grill. The pegs look to have snapped off at some point.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 05-27-2024, 08:09 PM
I believe the peg is the pin of the aluminum rivet
Old 05-27-2024, 10:49 PM
Default tabs with rivets
This is a better picture from front looking up. I believe they are aluminum rivets with a metal.pin. each grill has 2. But the mystery question is why I have onevwith no hole on tab or rivets. and another member same on his 71? Is riveted grill a 1 year only item too? or maybe I got a donor early repop? I'm guessing. if repops trim isn't riveted I guess it's an easy fix just drill small hole install a rivet so the trim.doesnt rattle off. I have been told repops are nice and that original are built better so guess Im.confused and curious about this rivet factory install.
ID:	634385   Click image for larger version
