Forum: Pontiac - Street
06-11-2024, 10:01 AM
06-06-2024, 08:22 AM
05-03-2024, 12:35 PM
03-12-2024, 12:03 PM
03-02-2024, 09:58 AM
11-16-2023, 11:07 AM
09-14-2023, 09:47 AM
Thanks guys
I would like to thank Jim Hand ,Cliff Ruggles and the guys at HO for for helping with my Pontiac hobby. I just got my TA to pass emissions here in North West Indiana for the 3rd time. It has...
08-29-2023, 09:34 AM
04-25-2023, 09:53 AM
This tells you how old I am. When I taught auto...
This tells you how old I am. When I taught auto mechanics in high school the tires would have marks either on the bead (an indentation) or a paint mark on the sidewall which would tell the lightest...
02-16-2023, 11:05 AM
01-05-2023, 11:28 AM
12-02-2022, 10:40 AM
To me Chevrolet’s lighter rotating assembly and...
To me Chevrolet’s lighter rotating assembly and light weight block plus their cylinder head design were the reason people raced them instead of Pontiacs on the short tracks.. And I’ve been a Pontiac...
11-10-2022, 10:58 AM
10-05-2022, 11:00 AM
I worked at Chevron gas station when my last 2...
I worked at Chevron gas station when my last 2 years of college. I bought Chevron DELO for $8 dollars a case of 24. I changed oil and filter every 2 months on my 67 Catalina. I had that car for...
08-29-2022, 10:56 AM
07-24-2022, 10:36 AM
I used to own a 67 Catalina 2 door Sport Coupe...
I used to own a 67 Catalina 2 door Sport Coupe with a 325 HP 400. It had a Carter AFB and dual exhausts with a 2.41 rear. The turbo 400 trans would shift out of 2nd gear at 90 mph. I learned 35...
05-05-2022, 10:34 AM
03-26-2022, 09:38 AM
11-20-2021, 01:11 PM
The last time I changed engine mounts I had a...
The last time I changed engine mounts I had a difficult time with through bolts. So, I kept the bolts to the block loose while I installed the through bolts, then I torqued the bolts to the block.
08-12-2021, 09:57 AM
06-24-2021, 10:57 AM
04-12-2021, 09:48 AM
01-09-2021, 12:59 PM
06-14-2020, 09:23 AM
I have a 56 Buick with a standard trans. The...
I have a 56 Buick with a standard trans. The Buick shop manual says to get rid of a vibration due to engine unbalance, is to one at a time put washers on clutch a bolt until the vibration goes...
04-20-2020, 09:42 AM
I rebuilt my Trans Am box three years ago. The...
I rebuilt my Trans Am box three years ago. The seals are pretty easy to do. There are many You tube videos on overhauling those GM boxes. Rebuilding is not for sissies but the seals can be done by...
