Showing results 1 to 10 of 10
Search took 0.03 seconds.
Search: Posts Made By: helmerrock
Forum: 67-69 Firebird TECH 03-08-2026, 06:30 PM
Posted By will slow gto
Always nice getting these updates and it sounds...
Always nice getting these updates and it sounds like you did some great improvements. You did have the original nylon tooth timing gear so you were wise to open it up and replace that. 66-70 Pontiac...
Forum: 68-69 GTO Tempest & LeMans TECH 02-24-2024, 07:30 AM
Posted By johnta1
Pontiac Cam Codes...
Pontiac Cam Codes (http://www.wallaceracing.com/camcode1.htm)
Forum: THE LOBBY 07-03-2023, 06:33 PM
Posted By pont3
Does anybody else watch Adam-12?
I just finished watching an episode that featured a 1970 Judge! It's just so neat watching the cars we value so much now being so nonchalantly treated back then. This particular episode aired in...
Forum: THE LOBBY 04-11-2023, 12:58 PM
Posted By Ram Air IV Jack
Here is a true story about a Jiffy Lube location...
Here is a true story about a Jiffy Lube location in the Chicago area I heard from a regional manager of that company. Years back, a high-end Mercedes drove into one of those locations because the...
Forum: THE LOBBY 02-26-2023, 10:10 AM
Posted By goat69SD
This car had a bent frame from an accident. The...
This car had a bent frame from an accident. The frame was original and the car had manual drum brakes and no power steering. Or at least that is the way it was when I got it. It did have the bright...
Forum: THE LOBBY 01-25-2023, 01:36 PM
Posted By Baron Von Zeppelin
Same could be pondered about the Rally2 wheels it...
Same could be pondered about the Rally2 wheels it is wearing.
They even look 7 or 8 inches wide too.
Its a Very neat car.
Imagine that lightweight being openly available for order in 1968 with a...
Forum: Pontiac - Street 09-20-2022, 01:13 PM
Posted By P@blo
I run the summit 2801 in a 9.25:1 CR 400 with...
I run the summit 2801 in a 9.25:1 CR 400 with headers and second B-man's motion. Had a magnum 280H prior to that and was clearly not a good choice. Sounded cool at idle but that is about it.
The...
Forum: Pontiac - Street 08-27-2021, 10:39 PM
Posted By Formulajones
Dad runs the 2" super comp headers on his 69 GTO....
Dad runs the 2" super comp headers on his 69 GTO. They actually fit quite well and have decent ground clearance. I also never had to modify the linkage rod from the steering column. His is a...
Forum: Pontiac - Street 06-21-2020, 11:14 AM
Posted By KEN CROCIE
Best Gasket seals don't like aftermarket cranks...
Best Gasket seals don't like aftermarket cranks with coarse serrations .They tend to melt and stop sealing.
Poly seals don't like coarse serrations either. You get poly-rubber dust as the serrations...
Forum: Pontiac - Street 05-09-2019, 06:02 AM
Posted By steve25
Your stated 9.77 compression, what heads was that...
Your stated 9.77 compression, what heads was that with and what Bore size is the 400?
