Forum: Pontiac - Street
04-21-2024, 09:38 AM
FWIW many folks have found more power with...
FWIW many folks have found more power with increased air flow using a Quadrajet. Many times folks have found a power gain going from the "750" CFM unit to a large primary venturi "800" CFM unit. Many...
02-13-2024, 07:50 AM
12-25-2023, 08:53 AM
12-01-2023, 10:03 AM
I never drilled the pump for increased feed. ...
Cooler line should be in the 25-45PSI range, but i suppose 60 can happen.
Hot fluid exits Case cooler line from Converter. Cooled fluid enter TH400...
Forum: Pontiac - Race
08-14-2023, 02:27 PM
I am going to put in a plug for Butler...
I am going to put in a plug for Butler Performance just because I think their rotating assembly package is a pretty good deal. The package includes the crank, rods, pistons, rings, wrist pins, and...
07-10-2023, 07:24 PM
12-31-2022, 05:17 PM
11-19-2022, 09:37 AM
11-18-2022, 10:53 PM
11-16-2022, 12:48 AM
11-14-2022, 10:14 PM
11-05-2022, 05:15 PM
I like the plan of an oil change and filter...
I like the plan of an oil change and filter inside inspection. Before you isolate the engine from everything else, a quick check is to set the idle at about 1000 RPM. Use insulated pliers and pull...
10-08-2022, 11:48 PM
10-08-2022, 08:52 PM
1 hp = 746 watts.
Assuming 100% efficiency...
1 hp = 746 watts.
Assuming 100% efficiency in the alternator (all physical energy used to spin the alternator is converted to electrical energy output, no losses to heat, friction or the...
08-14-2022, 12:46 PM
07-08-2022, 02:49 PM
06-19-2022, 03:06 PM
06-12-2022, 01:15 PM
05-01-2022, 10:12 AM
04-17-2022, 06:47 PM
03-05-2022, 03:24 PM
12-14” is just about right. I’m not sure why it...
12-14” is just about right. I’m not sure why it would be hurting anything only being that high. Just get good adjustable shocks on the front. Use those to soften the landing. My car runs best when...
03-04-2022, 08:59 PM
02-21-2022, 08:22 PM
Ask yourself why they are moving to...
Ask yourself why they are moving to facebook...One reason is, on FB if someone is being a buttdart, you can pretty much tell them what you think...This site censors your comments, and then you have...
02-13-2022, 01:29 PM
05-19-2021, 06:01 PM
