Showing results 1 to 7 of 7
Search took 0.13 seconds.
Search: Posts Made By: 71HOT/A
Forum: The Body Shop TECH 04-08-2022, 07:47 PM
Posted By 71HOT/A
Stop heating and cooling that panel. Working...
Stop heating and cooling that panel. Working across the body line above the soft spot, lightly tap with a body hammer. Lots of light taps directly on t he body line, maybe 12-16 inches across. As you...
Forum: The Body Shop TECH 11-09-2021, 11:10 AM
Posted By 71HOT/A
Weld through primer will out gas and ruin any...
Weld through primer will out gas and ruin any welds with mig or tig because the out gassing will interfere with the shielding gas. Weld through should only be used with resistance, aka spot-welding....
Forum: 70-72 GTO Tempest & LeMans TECH 10-29-2015, 07:36 PM
Posted By 71HOT/A
Fall colors
Summer's over. Here comes the dark, cold, gray, and nasty seasons.http://www.forums.maxperformanceinc.com/forums/attachment.php?attachmentid=411693&stc=1&d=1446161623
Forum: 70-73 Firebird & TA TECH 01-26-2014, 01:47 PM
Posted By 71HOT/A
Still looking for the build sheet. I got this...
Still looking for the build sheet. I got this from PHS Friday but it shows nothing about the gearing.350841
Forum: Pontiac - Race 01-25-2014, 12:08 AM
Posted By 71HOT/A
I bet that got a C+ at the community college...
I bet that got a C+ at the community college welding class! All kidding aside that is some super nice work.
Forum: 70-73 Firebird & TA TECH 01-13-2014, 08:52 PM
Posted By 71HOT/A
349256Axle code pics, I haven't had time to look...
349256Axle code pics, I haven't had time to look for car pics.
Forum: 70-73 Firebird & TA TECH 12-07-2013, 11:47 PM
Posted By 71HOT/A
The hood and metal scoop door were grounded to...
The hood and metal scoop door were grounded to reduce radio noise.
