Forum: Pontiac - Race
05-18-2022, 03:21 PM
05-18-2022, 09:52 AM
03-06-2022, 03:01 PM
WE did pre production testing for Isky on the...
WE did pre production testing for Isky on the bushed lifters,We have them running with 400#plus seat pressure,1200# plus open pressure at 1.00inch plus net lift some at 1.100..They were the first to...
07-25-2021, 04:09 PM
Firing order connects to Plenum manifold...
Firing order connects to Plenum manifold distribution,Thermal grid and hit on crankshaft position.Traditional Pontiacs have the pass side cylinders ahead of the drivers side on the crank..Dyno...
04-25-2021, 01:11 AM
04-11-2021, 03:55 PM
07-15-2020, 05:34 PM
05-25-2020, 10:21 AM
BSFC.Is a measurement of Pounds of fuel per...
BSFC.Is a measurement of Pounds of fuel per Horsepower Hour.It shows how efficiently an engine is performing.For example well refined race engines will be mid to high 30s to low 40s.A Q-Jet on a dual...
05-24-2020, 08:09 PM
02-14-2014, 06:17 PM
Looks like 60 on the first 4 then 55 on the...
Looks like 60 on the first 4 then 55 on the rear.Going to be a new core and will probably move lobes for better pushrod angle.Existing lobe location will allow .090-.100 offset can go .150 with new ...
01-25-2014, 01:26 AM
01-11-2014, 12:23 PM
Yes...you should port your heads! These things...
Yes...you should port your heads! These things (Pontiacs) always need more air moving through them . Your head otb is about 290 ish??? in intake cfm . Can gain about 40 cfm in the induction tract....
01-10-2014, 05:50 PM
01-08-2014, 12:53 AM
12-29-2013, 01:03 PM
So how many Eddy Pro-Ports were sold,A handful!...
So how many Eddy Pro-Ports were sold,A handful! Not a good ROI,But Edelbrocks resources took 2 plus years to get them on the shelves and the head is not all it could have been.Tiger Customs were made...
12-29-2013, 12:46 AM
12-28-2013, 01:26 AM
12-27-2013, 08:00 PM
12-15-2013, 01:26 PM
12-14-2013, 12:42 AM
12-01-2013, 07:06 PM
In mid 90s we did some development work for a...
In mid 90s we did some development work for a company doing EFI manifolds for 5.0-5.8 Fords.The TFS High Port was used on many of there test engines ,The final configuration of the intake manifold...
11-02-2013, 11:05 PM
10-23-2013, 05:58 PM
We have valves,springs ,retainers...
We have valves,springs ,retainers ,camshaft,Waiting on manifold,finish welding on heads and Jesel,Have revised prototype Jesesl stands and rockers here,Pistons are here,final mock up when rest of...
04-28-2013, 06:37 PM
Thanks Dan , was nice meeting you as well . One...
Thanks Dan , was nice meeting you as well . One more pic of the seat ring experiment in the chamber just to make sure everything works out from the test head to this pair. both valve guides have been...
04-28-2013, 02:09 PM
