Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Showing results 1 to 18 of 18
Search took
0.02
seconds.
Search:
Posts Made By:
hfpjr76
Forum:
60 & Older Pontiac TECH
03-19-2022, 08:27 AM
39
Swapping king pins for balljoints 55
7,399
Posted By
buds56
My experience with 56's I had. The first...
The first one I got was a bit rough, I cut the frame and put in a 77 trans am subframe, it actually fit pretty good for track width. The engine was going to sit way...
Forum:
03-19-2022, 01:26 AM
39
7,399
Posted By
Kingman Man
PontiacSafari.com, in Garage section has an...
PontiacSafari.com, in Garage section has an article on king pin to ball joint swap, might fit into your plans! Kingman Man
Forum:
03-13-2022, 02:33 PM
39
7,399
Posted By
Putter
Another advantage to using the crossmember from...
Another advantage to using the crossmember from heidt’s is that the front end and bumper bolt up to the stock frame as does the radiator.
Forum:
03-13-2022, 02:25 PM
39
7,399
Posted By
Putter
To cut or not to cut
Using the Heidt’s mustang 2 setup you do not have to cut the frame off it replaces the stock crossmember. That was on a 1948 Chevy sedan delivery…Pontiac may be different., but it worked very slick...
Forum:
03-10-2022, 09:12 PM
16
Moving brake to firewall
3,794
Posted By
Goatracer1
Speedway Motors (and probably others ) sells a...
Speedway Motors (and probably others ) sells a whole kit for mounting the master on the firewall. Comes with bracket and pedal.
Forum:
06-18-2021, 06:41 PM
16
3,794
Posted By
Sleepy33
Took a couple pictures of my pedal assy today ...
Brian
Forum:
01-21-2021, 06:14 PM
16
3,794
Posted By
Bill Eveland
I have mine on the firewall. I welded in a 1/8"...
I have mine on the firewall. I welded in a 1/8" to reinforce the area. I use a 55 Chevy pedal assembly and a mopar mc. I couldn't use the full assembly, the speedometer was in the way so made a...
Forum:
01-21-2021, 04:12 PM
16
3,794
Posted By
Scarebird
Thanks - We do, they are here: ...
http://scarebird.com/index.php?route=product/product&path=96&product_id=123
https://scarebird.com/image/cache/catalog/WWD%20comp-213x213.JPG
I was not...
Forum:
01-20-2021, 11:23 PM
16
3,794
Posted By
Scarebird
On a customer's car we made a bracket for a...
On a customer's car we made a bracket for a Wilwood remote dual master - worked fine. He nor us wished o butcher the defroster.
Forum:
01-20-2021, 07:15 PM
16
3,794
Posted By
694.1
Pretty sure that you need to eliminate the...
Pretty sure that you need to eliminate the defroster when you move the Master cyl.
I looked at a car a number of years ago that was done very poorly and the seller endured a lot of disgusted tire...
Forum:
01-06-2021, 02:10 PM
39
7,399
Posted By
Bill Eveland
If you mount the engine in stock location and use...
If you mount the engine in stock location and use the gearbox also on the clip, it should be ok just buy headers for the frame stub your using. The 55-57 steering gearbox makes it a pita for headers....
Forum:
01-06-2021, 12:00 AM
39
7,399
Posted By
Bill Eveland
I would actually prefer a rear steer clip if was...
I would actually prefer a rear steer clip if was to do one, meaning gearbox behind steering like it currantly is. 1st gen f body or 68-74 x body nova etc... Control arms angles will be much better,...
Forum:
01-04-2021, 07:42 PM
39
7,399
Posted By
694.1
"Taffy pull" is an old expression and a "polite"...
"Taffy pull" is an old expression and a "polite" euphemism for boxing the clown, spankin' the bacon, etc.
Forum:
01-04-2021, 07:05 PM
39
7,399
Posted By
694.1
'58 Olds lower arms will work too but are hard to...
'58 Olds lower arms will work too but are hard to find. Then you still need to fab up something for the upper.
Then there is the whole modern master cylinder/peddle thing taffy pull.
Good looking...
Forum:
01-04-2021, 05:14 PM
39
7,399
Posted By
Sirrotica
The second Gen has Pontiac mounts already on it...
The second Gen has Pontiac mounts already on it if it came from a Firebird with a Pontiac V8, if not it's pretty simple to change one over to Pontiac mounts, if it was from a camaro. Really the...
Forum:
01-04-2021, 05:04 PM
39
7,399
Posted By
KiwiStarChief
Hi Harry, I welcomed you into the Tri-five.com...
Hi Harry, I welcomed you into the Tri-five.com forum when you joined, so hello again. My '57 Star Chief has a front clip from a 1978 Monte Carlo, which gives all of the modern advantages of disc...
Forum:
01-04-2021, 04:35 PM
39
7,399
Posted By
Sirrotica
Many people just swap a 2nd gen subframe and have...
Many people just swap a 2nd gen subframe and have availability of easy to find replacement parts, rather than a trunnion front end that hasn't been used since 1957.
Granted, cutting the frame stub...
Forum:
01-04-2021, 04:15 PM
39
7,399
Posted By
Bill Eveland
Was that the Rodders Digest article using the 58...
Was that the Rodders Digest article using the 58 Control arms? I think I remember a Heidts mII crossmember setup as well.
Here's the article about using 1958 parts. ...
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
11:24 AM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
