Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Showing results 1 to 18 of 18
Search took
0.02
seconds.
Search:
Posts Made By:
goatboy1970
Forum:
61-77 GTO, Tempest & LeMans Parts For SALE
05-06-2023, 07:15 PM
1
New '70 GTO/Firebird 400 & 455 emissions decals
337
Posted By
Verdoro 68
I just produced corrected versions of the '70 emissions decals fixing some of the omissions and mistakes on the repros that are out there doing my best to make them as spot on to OEM examples as I...
Forum:
The Body Shop TECH
04-16-2023, 03:27 PM
18
Best Car Cover Setup
1,004
Posted By
The dust isn't going to be that big of a problem...
The dust isn't going to be that big of a problem with that much rain. Just make sure you have no leaks whatsoever. If you see water in the trunk or have wet carpet track the leak down and fix it...
Forum:
The Body Shop TECH
04-16-2023, 03:16 PM
18
1,004
Posted By
Stuart
I think in your environment I'd leave it...
I think in your environment I'd leave it uncovered - yes, dirt and dust will collect on the surface, but it isn't going to scratch the paint if you don't rub it around. Just be careful when washing...
Forum:
The Body Shop TECH
04-16-2023, 02:57 PM
18
1,004
Posted By
OG68
Moisture will collect under a plastic cover and...
Moisture will collect under a plastic cover and damage the paint when heated up. I ruined the paint on my 73 Nova when I used a plastic cover. And this was in the SoCal desert
Forum:
Interior TECH
04-13-2023, 12:11 PM
2
Door Panel Assembly Tutorial
761
Posted By
rambow
I followed this guide ...
I followed this guide (https://www.chevelles.com/threads/door-panel-how-to.271914/)when I did my unassembled panels for my 68.
One thing of note that I had to do was to flatten the original...
Forum:
70-72 GTO Tempest & LeMans TECH
01-29-2023, 06:32 PM
4
Head Bolt Length
799
Posted By
'ol Pinion head
3 5/8" version on modern Dports in that...
3 5/8" version on modern Dports in that position.
Forum:
Suspension TECH
01-22-2023, 06:29 PM
38
70 Steel Wheel Codes
2,776
Posted By
'ol Pinion head
On a 09A or even early 09B body build GT-37, that...
On a 09A or even early 09B body build GT-37, that was actually built before the big strike, I'd expect a JT coded wheel most likely dated in the 8/13/70 range. 8/13/70 is a valid date, know of a set...
Forum:
Suspension TECH
01-22-2023, 11:07 AM
38
2,776
Posted By
unruhjonny
ok then, based on what I am reading now, early...
ok then, based on what I am reading now, early 70’s should probably be XE, while late should be HF.
Forum:
Suspension TECH
01-22-2023, 11:03 AM
38
2,776
Posted By
SD455DJ
I could only access the original wheels from the...
I could only access the original wheels from the 09E Baltimore built Tempest and all 5 are 8/2/69, or possibly 8/12/69 (the '1' in the 12 is very faint), and XE coded. I was mistaken in my earlier...
Forum:
Suspension TECH
01-21-2023, 09:19 AM
38
2,776
Posted By
'ol Pinion head
Heres some dates, am sure have more HF's & poss...
Heres some dates, am sure have more HF's & poss some more XEs. Have a considerable amount of mounted steel wheels to break down.
K-1-0 6 @ 14 HF
K-1-0 9? @ 18 HF (the 9 is upside down)...
Forum:
Suspension TECH
01-20-2023, 05:37 PM
38
2,776
Posted By
unruhjonny
My experience from big car shows doesn't lend to...
My experience from big car shows doesn't lend to a post like that (#27) as the end-all.
It reads to me as though there may have been two codes used depending on build date;
As an example all the...
Forum:
Suspension TECH
01-19-2023, 07:05 PM
38
2,776
Posted By
unruhjonny
Can anyone explain for me the HF vs XE 14x6"...
Can anyone explain for me the HF vs XE 14x6" steel wheels that both seem to be purported in this thread as being for a 1970 GTO?
(I am currently adding info from this thread to my wordpad file on...
Forum:
Suspension TECH
01-18-2023, 03:52 PM
38
2,776
Posted By
Shiny
I looked and find my 70 LeMans wheels are XE...
I looked and find my 70 LeMans wheels are XE code. I don't know if they are original but have no reason to believe they were changed.
Forum:
Suspension TECH
01-16-2023, 10:25 PM
38
2,776
Posted By
unruhjonny
The CL code was used on 1970-1972 Firebirds and...
The CL code was used on 1970-1972 Firebirds and Camaros with F70/14 & F78/14 tires.
This is a great discussion, I’m going to refer to it tomorrow and update my notes on Rally II and steel wheel...
Forum:
Suspension TECH
01-16-2023, 06:37 PM
38
2,776
Posted By
SD455DJ
My '70 Tempest (400 2-bbl/TH400) and '70 LeMans...
My '70 Tempest (400 2-bbl/TH400) and '70 LeMans (350 2-bbl/M-20 4-speed) both have HF 14x6 steel wheels. I'm quite sure the GTO's also came with them (HF code) too if Rally II's weren't ordered.
Forum:
Suspension TECH
01-16-2023, 06:15 PM
38
2,776
Posted By
'ol Pinion head
Early 70 model A-body's equipped with 14x6 rally...
Early 70 model A-body's equipped with 14x6 rally II wheels received JL code wheels. Have sold numerous date matched sets of these. The JL's were made up through 11/25/69. The same day 11/25/69, the...
Forum:
Suspension TECH
01-16-2023, 06:07 PM
38
2,776
Posted By
'ol Pinion head
70 & 71 Pontiac A-body used the HF code 14x6...
70 & 71 Pontiac A-body used the HF code 14x6 wheel on GTO's & V8 A-body's. Im not sure how much longer this code was used, but I am watching when in old yards.
'70 Pontiac A-body's did NOT use ...
Forum:
Suspension TECH
01-16-2023, 03:30 PM
38
2,776
Posted By
unruhjonny
I want to help, but to date I haven't compiled...
I want to help, but to date I haven't compiled ALL steel wheel codes, becasue that list would get huge;
This is what I can offer;
I have a 1970 Pontiac 14x6" steel wheel code of 'AM' as being for...
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
08:06 PM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
