Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 3
1
2
3
Showing results 1 to 25 of 63
Search took
0.01
seconds.
Search:
Posts Made By:
bhill86
Forum:
77-81 Firebird & Trans Am TECH
04-18-2024, 12:49 PM
9
Found another one.....1979 Formula W72
310
Posted By
bhill86
That’s beautiful! I’m jealous. I’d love to have a...
That’s beautiful! I’m jealous. I’d love to have a formula someday
Forum:
Pontiac - Street
04-16-2024, 11:48 PM
25
Coolant in oil
1,848
Posted By
bhill86
Thought I’d come back to update. I snuggled up...
Thought I’d come back to update. I snuggled up the bolts on the timing chain cover and got 6 or 8 good heat cycles on the engine since adding the stop leak and the leaks appears to have…well,...
Forum:
Heating & Cooling TECH
04-01-2024, 04:45 PM
13
Fel-Pro T'stat Housing Gasket Wicking Itself to Death
577
Posted By
bhill86
I too use the chrome neck with an o ring. I...
I too use the chrome neck with an o ring. I believe I tried RTV in the past on the paper gasket. The chrome isn’t my favorite looking (although not that bad) but it has sealed the best and as...
Forum:
Collectibles FOR SALE
03-22-2024, 07:34 PM
13
nOS Led Zep 1&2 8 tracks
584
Posted By
bhill86
It’s not difficult to rebuild them. Foam pads are...
It’s not difficult to rebuild them. Foam pads are readily available and replacing the tape foil/splice is easy and they’re also available. I have around 100 tapes and many of them had good pads...
Forum:
02-14-2024, 11:13 AM
34
I thought I was pretty good at electrical, apparently I suck.
1,666
Posted By
bhill86
If you’re referring to that “digital clock” plug...
If you’re referring to that “digital clock” plug that’s not for the clock in the tach. In fact, it’s not used in f bodies. The clock wire does terminate in the harmonica.
Forum:
Interior TECH
01-01-2024, 03:03 PM
12
Various Questions On A 77 T/A Interior
1,073
Posted By
bhill86
Only one I can answer for you is #4 which is...
Only one I can answer for you is #4 which is black. I don’t have any experience with 2 tone interiors to help you further
Forum:
11-28-2023, 09:42 PM
5
Idle stop solenoid, W72
508
Posted By
bhill86
I used one that was listed for a corvette I...
I used one that was listed for a corvette I think. I just made some spacers to position it accordingly with plans to make a different bracket at some point.
Forum:
THE LOBBY
11-10-2023, 10:58 AM
70
STOOPID PEOPLE!
5,511
Posted By
bhill86
At least the last two guys had the decency to...
At least the last two guys had the decency to reach back out to admit their mistakes. I don’t imagine that happens too often.
Forum:
Interior TECH
11-03-2023, 07:11 AM
11
2nd gen sun visor with mirror
1,190
Posted By
bhill86
Thank you! I hadn’t ever been able to find a...
Thank you! I hadn’t ever been able to find a picture of one until now
Forum:
74-76 Firebird & TA TECH
10-25-2023, 08:42 PM
3
Change to Concealed Wipers
769
Posted By
bhill86
How many wires are on your non concealed wiper...
How many wires are on your non concealed wiper motor? My 76 wiring diagram seems to only show one switch and wire setup so I’ll guess yours has three like my 77 with concealed wipers. Assuming they...
Forum:
10-20-2023, 06:54 PM
3
Best side window weatherstripping
291
Posted By
bhill86
Thanks. I used a set years ago (forget the brand)...
Thanks. I used a set years ago (forget the brand) thay we’re ok but not great. Recently I chose a set from a different company others reported to have had luck with and although they’re a significant...
Forum:
Pontiac - Street
10-18-2023, 01:01 PM
9
HURST SHIFT HANDLE REMOVAL
337
Posted By
bhill86
Take either a nice rigid feeler gauge or I think...
Take either a nice rigid feeler gauge or I think I used a razor blade, and wedge it between the handle and the little isolator on the drivers side only. Then pull on the handle and it should slip...
Forum:
09-27-2023, 06:45 PM
15
79 Trans Am AC system restore stock? or aftermarket?
1,019
Posted By
bhill86
Without rereading the stage 3 kit description, my...
Without rereading the stage 3 kit description, my stage 2 kit includes everything except the thermal switch if I remember correctly. (Different than the low pressure switch which is included). The...
Forum:
09-26-2023, 04:44 PM
15
1,019
Posted By
bhill86
I agree, my fan stays on high, likely max...
I agree, my fan stays on high, likely max (recirculate), almost indefinitely on hot days. I’ve read about n this forum of people using a different fan that blows more air but I don’t think I ever saw...
Forum:
09-25-2023, 09:44 PM
15
1,019
Posted By
bhill86
Sorry, here…....
Sorry, here…. https://www.originalair.com/engine-compartment-gm
It’s under original air group which is a part of classic auto air.
Forum:
09-25-2023, 03:22 PM
15
1,019
Posted By
bhill86
I installed a Classic Auto Air system in my 77...
I installed a Classic Auto Air system in my 77 400 being in a similar situation as you. I was missing all components beyond the evaporator core but flushed mine, it had no holes and everything under...
Forum:
09-08-2023, 12:09 PM
1
No Headlights
231
Posted By
bhill86
Responded on your other thread
Forum:
70-73 Firebird & TA TECH
09-07-2023, 09:01 PM
18
need help to run the wire harness for my electric trunk release
789
Posted By
bhill86
I’d guess (and it’s just a guess) passenger side...
I’d guess (and it’s just a guess) passenger side would be correct seeing as how power originally came from the area near the glovebox and of course the button is mounted there. I opted to use a...
Forum:
08-31-2023, 03:24 PM
22
want to add a second rear speaker to my 72 formula
1,328
Posted By
bhill86
With the value of the 70-77 radios (especially a...
With the value of the 70-77 radios (especially a red dot) I think I’d avoid modifying it. Just my honest opinion though and of course to each their own.
Forum:
08-30-2023, 05:53 PM
22
1,328
Posted By
bhill86
My 77 does have the second speaker cutout in the...
My 77 does have the second speaker cutout in the package tray so I’d imagine your 72 might too.
Forum:
THE LOBBY
08-26-2023, 09:09 PM
7
Bob Barker
529
Posted By
bhill86
99 eh? Close as possible without going over…..
Forum:
Interior TECH
08-24-2023, 10:07 AM
11
1,190
Posted By
bhill86
As far as I can tell it was a RPO. It’s listed in...
As far as I can tell it was a RPO. It’s listed in my dealer invoice as D64 as I recall.
I should’ve at least taken a picture of the visor I had with the mirror attached. It was REALLY bad though.
Forum:
08-22-2023, 09:48 PM
6
78 Firebird tail light harness wires identification
550
Posted By
bhill86
Signal wires double as brake light wires. Those...
Signal wires double as brake light wires. Those come from the turn signal switch in the column. Pink is fuel sender as mentioned and brown is parking light circuit.
Forum:
Pontiac - Street
07-27-2023, 09:28 AM
34
Tuning for A/C compressor load
1,262
Posted By
bhill86
For the record the late 70s AC solenoids were...
For the record the late 70s AC solenoids were wired after the low pressure switch so if the compressor cycles off the solenoid loses power.
Forum:
07-20-2023, 11:43 AM
26
Formula Wheel Resto
1,488
Posted By
bhill86
Thanks for the info on the low luster clear....
Thanks for the info on the low luster clear. Maybe I’ll try it out. Interesting on the texture too. Maybe my wheel had been messed with by someone. Come to think of it though the camel wheel was very...
Page 1 of 3
1
2
3
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
02:13 AM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
