Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 2
1
2
Showing results 1 to 25 of 46
Search took
0.02
seconds.
Search:
Posts Made By:
ID67goat
Forum:
The Body Shop TECH
03-23-2024, 10:17 PM
18
Anyone Heard from Paul at Fast Lately?
1,308
Posted By
ID67goat
Website must be very old…did you see the labor...
Website must be very old…did you see the labor rates!.?
Forum:
THE LOBBY
01-15-2024, 09:33 PM
11
Free malware and virus program?
725
Posted By
ID67goat
Have used Malwarebytes in the past with good...
Have used Malwarebytes in the past with good results..
Forum:
THE LOBBY
01-10-2024, 01:39 PM
120
AI Images - Fun or Scary?
12,577
Posted By
ID67goat
The chief one cracks me up! Ripped skinny jeans...
The chief one cracks me up! Ripped skinny jeans and boots with frills? Don’t think I have seen that before….
Forum:
THE LOBBY
11-03-2023, 08:19 PM
5
NEW HERE !!!!!
457
Posted By
ID67goat
Tecno BD4H is a Chinese phone model… More...
More than likely this is a scammer!
Forum:
Pontiac - Street
10-27-2023, 02:26 PM
23
I want to make a charcoal fuel vapor vent to reduce gasoline smell.
1,338
Posted By
ID67goat
Just some feedback…….After installing basically...
Just some feedback…….After installing basically the same setup as you (Sniper, tanks inc, etc) I basically have no fuel smell in my garage anymore. Are you sure there is not a small leak somewhere...
Forum:
The Body Shop TECH
09-12-2023, 07:57 AM
21
Paint removal from aluminum
1,284
Posted By
ID67goat
Aircraft paint stripper might be another option. ...
Aircraft paint stripper might be another option. While messy, it shouldn’t damage the aluminum like blasting could..
Forum:
Pontiac - Street
09-07-2023, 09:01 PM
7
Camshaft break-in & longevity treatment
594
Posted By
ID67goat
Anyone know a good place to get cams nitrided?
Forum:
Pontiac - Street
08-28-2023, 03:05 AM
19
Suggestions for cleaning a white headliner
592
Posted By
ID67goat
Have had good luck with the Magic Erasers….does a...
Have had good luck with the Magic Erasers….does a very good job of removing dirt from the grain of the material and is not messy.
Forum:
Pontiac - Street
08-22-2023, 08:54 PM
9
vacuum leak?
693
Posted By
ID67goat
Starter fluid, brake clean,, propane…..can be...
Starter fluid, brake clean,, propane…..can be used.
Old brittle vacuum lines, intake gaskets, brake booster, etc. can all be possible sources
Forum:
Pontiac - Race
08-10-2023, 09:52 PM
25
Pistons and Rings
1,031
Posted By
ID67goat
Talk to Paul K, he should be able to hook you up...
Talk to Paul K, he should be able to hook you up with some Racetec pistons with modern ring pack, coated, etc.
Forum:
THE LOBBY
05-24-2023, 09:23 PM
22
Best form of payment for $6,000 item
1,066
Posted By
ID67goat
Always wanted one of those bikes, too bad you are...
Always wanted one of those bikes, too bad you are so far away.
Good luck with the sale!
Forum:
Pontiac - Street
02-01-2023, 10:44 PM
218
SpeedMaster CNC ported heads on sale
19,718
Posted By
ID67goat
From heads and intakes that I have: “As...
“As cast” the port entrance has a cnc finish about 0.200 deep at the top and bottom of the ports and then about 0.300 on the sides. This opening is roughly...
Forum:
THE LOBBY
01-31-2023, 02:18 PM
17
Aussie TA crash - poor bugger
1,440
Posted By
ID67goat
Wonder how they know it’s a 7.4 liter? Isn’t 454...
Wonder how they know it’s a 7.4 liter? Isn’t 454 usually called a 7.4 liter.
Either way it looks like he was speeding down a narrow residential street like an idiot!
Forum:
Pontiac - Street
01-18-2023, 01:56 PM
27
Motor/tranny break in question
2,084
Posted By
ID67goat
Agree 100% on the above. Not sure I am convinced...
Agree 100% on the above. Not sure I am convinced about the transmission….as long as you have it filled to the proper level with gear oil it should not damage anything as all the gears will be...
Forum:
67-69 Firebird TECH
12-24-2022, 11:27 PM
11
Pontiac 8.2 4 pinion posi units.....ALL JUNK...
1,265
Posted By
ID67goat
Ford 9”. From Currie, Quick Performance etc. ...
Ford 9”. From Currie, Quick Performance etc. Bigger investment up front, but much larger selection/better parts to choose from.
Forum:
THE LOBBY
11-28-2022, 11:00 PM
162
ram air III d and IV round port A body exhaust manifold availability dates?
19,612
Posted By
ID67goat
Is this even a legit store? Has anyone ordered...
Is this even a legit store? Has anyone ordered from them?
Forum:
70-73 Firebird & TA TECH
11-26-2022, 11:26 PM
22
need some tips on fender alignment
2,581
Posted By
ID67goat
Are you aligning the fenders with the weight of...
Are you aligning the fenders with the weight of the car on all 4 tires on the ground? If on jack stands the subframe could sag and make the gap larger at the top.
Make sure to align doors to...
Forum:
Pontiac - Street
11-10-2022, 03:18 PM
15
67 gto mini starter
1,907
Posted By
ID67goat
I like my Robb MC starter....
Forum:
Pontiac - Street
10-08-2022, 11:49 PM
30
Finishing some upgrades for my 80 TA
2,973
Posted By
ID67goat
I think you can get the trim from McMaster… ...
https://www.mcmaster.com/edge-trim/heavy-duty-plastic-trim/
Forum:
Pontiac - Street
08-24-2022, 09:19 PM
29
Butler 400 block & rotating assembly
3,309
Posted By
ID67goat
Why not check with a reputable builder nearby...
Why not check with a reputable builder nearby that might be able to fix what you have or supply you with what you need? PaulK is not too far away from you...I am sure there might be others nearby...
Forum:
08-21-2022, 02:51 PM
12
1970 esprit still overheating
1,350
Posted By
ID67goat
When does it get hot? While cruising? While...
When does it get hot? While cruising? While stopped in traffic?
I would check the basics: Radiator not clogged up with debris, properly working clutch fan, and most important…check the tuneup...
Forum:
Test & Tune
07-09-2022, 01:25 PM
2
how do you put "the following user says thank you" at the bottom of someone's post?
1,590
Posted By
ID67goat
When replying, on the bottom right there is a...
When replying, on the bottom right there is a thumbs up icon. Click that and it will show up as a thank you..
Forum:
Pontiac - Race
06-19-2022, 12:03 AM
9
Crane cam kit
1,691
Posted By
ID67goat
Looks like a Crane 3/4 race cam right? :D
Forum:
THE LOBBY
06-03-2022, 11:41 PM
22
Tesla Phantom Braking Issue
2,108
Posted By
ID67goat
The 2018 Honda Accord that I had did the same...
The 2018 Honda Accord that I had did the same thing many times to me. Many dealer visits later they finally fixed it with a software update.
I really do not like the adaptive cruise control etc...
Forum:
THE LOBBY
04-02-2022, 02:37 PM
94
READ THIS IF YOU'RE HAVING WEIRD FACEBOOK PROBLEMS
9,663
Posted By
ID67goat
Is this forum hosted by Facebook or something? I...
Is this forum hosted by Facebook or something? I am only able to post a quick reply without getting the Facebook login page.
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
04:27 AM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
