Tim john |
01-06-2022 03:40 PM |
Not a 68 but a 69 bird convertible. I went with Vintage Air direct fit. Catered to the 69 model and everything went in smoothly, no issues. I also was able to use an original dash controller to run the system so the dash appears factory stock. Very pleased with the fit and performance. I installed everything at home by myself. Only a couple hickup, I needed to change out the binary switch for a trinary in which VA did so and I also needed a different compressor for my application, again VA did so. I needed a higher rpm unit. Both of these issues were resolved well before I began the installation. There was kind of a recall on the computer controller, at least a known issue that I had read/heard about and I ended up pulling the delivered one with the system to get the latest greatest. The unit would not go to medium or high speed once installed, changed out the board and all is well. 15 minutes to swap. I have no regrets. VA was always super helpful on questions and trouble shooting techniques. The unit is powerful in moving air, lots of it, both heat and cold (A/C).
Tim john---
