78-79 Intake Set Up w/ 6X Heads (Pontiac 400)
Here’s a clean 78-79 400 I take se up, has orig alum thermo neck w/ a new gasket, og bolts, EGR, & Holddown,( baffle will be needed) S Steel carb spacer, with a new gasket,
Also pair of complete 6X Heads, $275 for all , pick up. It’s heavy. Free pick up in the Detroit Area |
Hi
are your 6x heads -4 or -8? I am also detroit area thank you |
