-   Pontiac - Race (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=419)
-   -   Holley carb. Help identify!!!!!!!!!!!!!1 (https://forums.maxperformanceinc.com/forums/showthread.php?t=380245)
dennisk 08-06-2003 06:33 AM
This carb came on a car I bought. Did not run. Any ideas as to what cfm it is and if its worth rebuilding?
BigB 08-06-2003 07:23 AM
post the numbers on the front of the choke housing
http://img.villagephotos.com/p/2003-...32/noonova.jpg
1974 ventura
455
670 heads
victor
1050 dominator
250hp NOS
Tubbed
Caged
Lots more.
dennisk 08-07-2003 06:39 AM
#s are not legible.
BigB 08-07-2003 07:02 AM
i'm stumped. why does it only have one metering plate? Never seen that before...but then again..there is alot I haven't seen before.
Http://img.villagephotos.com/p/2003-...IX-noonova.jpg
1974 ventura
455
670 heads
victor
1050 dominator
250hp NOS
Tubbed
Caged
Lots more.
tom s 08-07-2003 07:10 AM
LOTs of holleys only have one jet block,the others use a plate.
Lloyd-TX 08-07-2003 07:50 AM
I dunno. Maybe some sort of OEM truck carb?
'72 Formula 455 - TH400, 3.08 posi, A/C, Y99 suspension, tach & gauges, AM-FM stereo, 8-track, Formula steering wheel, etc.; Lucerne Blue with Medium Blue deluxe Interior; 12.96 @ 104 MPH @ the '03 PSN's
Soon I'll starting a body-off restoration on a 72 GTO 455HO, TH400, A/C, etc.; Sundance Orange with Ivory buckets
68alpinebluegto 08-07-2003 08:20 AM
It is Definately a Model #4160 Holley Square Bore
It Appears to be a part # 0-1850
Here is the Description in the Holley Book for the above part#
This is a universal application Carb.
600 CFM
Non Emission
Manual Choke
Vacuum Secondaries
PMDRACER 08-07-2003 09:42 AM
I agree with jagjr. The size of the throttle bores as opposed to the gasket holes gives it away. Good carb for small engines like a 350 or a mild 400.
TIGER EFI - Electronic Fuel Injection for the Traditional Pontiac Engine. [email protected]
iron man 08-07-2003 11:49 AM
I think I have a couple of those at home, I'll check the numbers on them. I ran one on a mild 400 and it really did perform well. The 1407 Edelbrock 750 I replaced it with hasn't impressed me yet. http://forums.performanceyears.com/g...icon_frown.gif
dennisk 08-07-2003 03:48 PM
Thank you for the responses. Now is it worth rebuilding or Sell and put towards a new 1?
Crashmh 08-07-2003 04:32 PM
Since it has manual choke with plastic linkage and accelerator pump arm I'm 99% sure it is a 0-1850-3 or 4. It is the least expensive Holley 600 universal carb. The biggest problem with these is that it has a very fat idle circuit, they will generally run rich at idle. If you know your way around a Holley, pick up a renew kit or a trick kit, and a new vacuum secondary diaphram and have at it! (An assortment of secondary springs and a quick change kit wouldn't hurt!)
dennisk 08-09-2003 12:37 PM
Thanks guys, Next saturdays project. ENJOY the PONTIACS!!!!!!!!!!!!!!!!!!!!
superdutydave 08-12-2003 04:18 PM
Most likely 600-650 cfm emmisions calibrated carb (due to plastic appearing parts). Obviously corroded and burnt. Parts to rebuild and dial in (rebuild kit,Vac secondary spring kit,50cc pump,etc) probably would be atleast $200- so go buy a new carb and don`t feel bad.
