I want to fit a Power Antenna to my 1966 Grand Prix.
Anybody got accurate measurements where I drill the hole in the rear fender? http://forums.performanceyears.com/g...n_confused.gif And what size is the hole?? Experience is that marvellous thing that makes you recognise a mistake when you make it again. |
I have a 66 Bonneville conv't with a power antena in the rr 1/4. If you think it would be the same I can measure it tomorrow. http://forums.performanceyears.com/g.../icon_wink.gif
Another Red Light Nightmare http://forums.performanceyears.com/g...icon_smile.gif |
I'd look at the cars on the Grand Prix chapter web-sight at http://www.poci.org/
I would use a Uni-bit to cut the hole. It looks like a top with cutting edges on it.You can cut a little at a time till you reach your ideal size. Or use a knock out punch, any electrician should have either. Try to borrow, there both a little expensive to buy for 1 hole. If you have to use a hole saw, run the drill slowly in reverse while cutting. |
I'm doing the same to my '66 Catalina. 66SSE e-mailed me these pictures of the antenna location on one of his '66 Bonnevilles. I still haven't got to it, but these should work great!
And the other one.........
Guys, thanks a million. Those pictures and the advice is just brilliant http://forums.performanceyears.com/g...on_biggrin.gif http://forums.performanceyears.com/g...on_biggrin.gif http://forums.performanceyears.com/g...on_biggrin.gif
I'll be doing the job on Sunday. One more question. What size hole. I'll buy a new hole saw just for the job. Worth getting it right. http://forums.performanceyears.com/g...icon_smile.gif Experience is that marvellous thing that makes you recognise a mistake when you make it again. |
Even I could understand a pic like that. Good job 66SE
| All times are GMT -4. The time now is 08:38 AM. |
