-   -   PCV valve vs. plain old breather cap (https://forums.maxperformanceinc.com/forums/showthread.php?t=391144)
sloppy_steering 11-24-2004 08:17 PM
Hi everyone,
I've got a 68 firebird w/ a 350 in it. She's got a rebuilt Holley 750 and I was wondering. Whats better for performance? Should I continue to run my PCV valve in the valve covers to the manifold vaccum port on the back of the carb. Or should I use an open element breather cap on the valve cover and cap the manifold vaccum port? I don't have any emissions laws to worry about and I want the best performance I can get.
Thanks,
Brian
Hi everyone,
Thanks,
Brian
Schurkey 11-24-2004 08:54 PM
You will lose ZERO performance with a PCV valve, and you will cut your overall emissions about 80%.
In addition, your oil will stay clean longer, and it will increase bearing life because of less acid/moisture build up in the oil.
The PCV system was the first--and finest--bit of emission control engineering in the automotive world because it is dirt cheap, extremely reliable, and hugely efficient at reducing pollution.
Goatracer1 11-24-2004 09:04 PM
Your engine needs air flow through the crankcase so you should have an inlet(breather) and an outlet (either a pcv valve or a draft tube).
J_JAMNIK 11-25-2004 11:47 AM
I definitely agree with Schurkey! Ever seen rust on the inside of an old engine without a PCV valve?
