When installing rear control arm bushings on the rearend housing, which way does the bushings go in? The flange side towards the front or back? Does it even mater?
Anthony |
Anthony |
When I took my car apart, the flange was to the rear (outside), so I put it together the same way although it doesn't seem like it should make any difference.
My bolts through the bushings were inserted from the rear (outside).
Here's how it looked coming apart.
| All times are GMT -4. The time now is 05:53 PM. |
