-   -   Sending unit 67 Goat (https://forums.maxperformanceinc.com/forums/showthread.php?t=396022)
lampoon 07-15-2003 03:03 PM
Ok. I have the gastank off. To remove the sending unit do I tap it out? Or is there some twist trick? What tool do I use? http://forums.performanceyears.com/g...n_confused.gif I cant remember. Anyone know where to get replacement padding that goes on top of the tank between it and the trunk?
http://forums.performanceyears.com/g...n_rolleyes.gif
1970cat 07-15-2003 03:18 PM
should be a notched lock ring , put a screwdriver against the tab and tap it until it spins and unlocks
Brad B. Hillebrand 07-15-2003 04:43 PM
Ditto 1970Cat...
lampoon 07-16-2003 03:28 AM
Any idea about the padding?
stevek0629 07-16-2003 07:41 AM
I got my tank pad from PY, part number RPR71S for $22.00
Steve
lampoon 07-16-2003 08:28 AM
Thanks Steve. I just ordered it. When I get home I will attempt to tap out the sending unit.
Does PY sell replacement socks or is that something any auto part store carries?
lampoon 07-19-2003 06:03 PM
I cant find a replacement sock anywhere. I will add an inline filter before the pump but I'd like the sock as well. Ive read several; posts about AC Delco socks. The parts places around me say "discontinued" when I inquire. Ideas?
goatseeker 07-19-2003 06:39 PM
PY and Ames both carry replacement A/C Delco socks and pre-assembled socks on their complete sending units. For '66 the stock pickup tube is 5/16" - the replacement is 3/8" but it works fine. There is some difference in the sending units between A/C and non-A/C cars so make sure you get the correct one for your application.
Tim
http://kurtspontiac.homestead.com/TimSimpson66GTO.html
lampoon 07-20-2003 04:34 AM
I still cant find the replacement socks. It wont come up under any searches. Do you have a PY part number??? http://forums.performanceyears.com/g...icon_smile.gif
lampoon 07-20-2003 04:54 AM
Tim....how did the 3/8" fit on the 5/16"?
Does it cinch down with a metal wire or something?
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by goatseeker:
Tim
http://kurtspontiac.homestead.com/Ti...></BLOCKQUOTE>
engineer 07-21-2003 09:42 AM
don't do a search, just open the paper catalog and order it. It is still available at the auto stores and at the ford dealers as well.
