-   -   Vinyl Dye (https://forums.maxperformanceinc.com/forums/showthread.php?t=397369)
gr8dain 05-27-2004 06:27 PM
I am looking for the green dye for my interior. I did not see it in PY. Do they make it in green? Is it just a simple spray paint can? I am hoping to spray the dash cover I just got from PY. It comes black. I was thinking of keeping it black, but the two tone dash is not looking good. So I may paint the visible parts of the original dash pad black, or dye the cover green.
Is the dash cover plastic hard enough to use something other than dye?
I hope someone has used it and can help.
Thanks a lot,
Dain
Thanks a lot,
Dain
buzzojoe 05-28-2004 03:01 AM
PY shuld have the dye. Give them a call. If not look on the internet for Metro Mustang. They make vinyl dye in spray cans and are good to deal with.
I put a new PY dash pad in my 68 and used vinyl dye to color it Aqua from black. You have to use vinyl primer, then vinyl "prep" to make the dye stick correctly, then the dye. It worked GREAT for me.
Good Luck!
gr8dain 05-28-2004 08:15 AM
Thanks for the info
