-   The Body Shop TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=417)
-   -   Testing power window motors? (https://forums.maxperformanceinc.com/forums/showthread.php?t=398208)
Rusty 68 09-19-2004 08:40 PM
Does anyone know how to test power window motors once they have been removed from the car. I assume a direct 12v connection could fry them. Thanks
cal1808 09-19-2004 08:45 PM
12 volts to one wire ground to the other tests one way, switch the wires tests the other.
Forrest 09-19-2004 09:17 PM
ground the motor, then apply 12 volts to one of the terminals,(motor should go one; clockwise or counterclockwise)then apply 12 volts to the other terminal ( motor should go the opposite way)only apply the 12 volts to one terminal at a time! of course there is no load on them, so it is hard to tell if they really work well
