-   -   3 or 5 tab oil pan question (https://forums.maxperformanceinc.com/forums/showthread.php?t=398791)
medic 08-25-2003 02:35 PM
How do you tell which is which?
johnta1 08-25-2003 02:47 PM
The 3 tab pan will have 2 slots and a hole for the rear rubber gasket.
The 5 has 5 slots for the gasket.
johnta1
http://wallaceracing.com/johnta1plate.jpg
medic 08-25-2003 03:06 PM
OK but where are the slots and the hole located? is it on the rear of the pan and are there slots and hols in the pan itself?
johnta1 08-25-2003 03:20 PM
The rear of the pan rail that bolts to the block.Looks like a u-shape.
johnta1
medic 08-25-2003 03:50 PM
Ok still not to clear on this, I think we are talking about the area where i used a cork gasket. goes around the rear main cap, correct. I did have a rubber gasket with a couple of triangles on it but when I asked a question about using it no one answered. should I have used the rubber one also?
WARPed 08-25-2003 06:27 PM
No, believe it or not you did the right thing using the cork one. If your rear main cap has a grove to accept the cork gasket then you definitely do not want to use the rubber one.
with out questions there can be no answers
1969 Grand Prix
[email protected](1.358)
[email protected](1.342)
WARPed Tepee Forums
[email protected]
medic 08-25-2003 06:58 PM
Thanks warped
