I recently replaced the engine in my 91 grand prix with an engine out of a 94 corsica. basically only the block and heads were the same so i swapped everything but them. it runs great. no check engine light coming on but, the check gauges light comes on for about 10 mins every time i start it. all my gauges seem to work fine and everyting reads ok. i cant figure it out.
Have you deciphered the code that the light is transmitting?
AutoZone will give you a FREE key and booklet that tells you how to read the codes from the check-engine light. Could be as simple as emptying out the message, and then all will be fine. Let us know what you learn. Bob Trimpe |
you dont understand, the check engine light never comes on, just the check gauges light. sometimes its on for awhile and goes off, sometimes it stays on
| All times are GMT -4. The time now is 03:08 AM. |
