is anyone looking for any parts for a 69 bonne?
I am looking for a blue driver's door panel for a 4 door (with power windows).
sorry its has yellowish door panels an its a two door with manual window cranks
Hi Tyler,
What shape is the interior in? I could use door panels and seats and some odds and ends. I could also use front and rear valences, but I'm not sure if the ones on a '69 Bonne would fit a '69 Catalina. |
the door pannels are ok, the front seat is a bench and I will need to take another look at it to be able to tell you the condition, its really dirty. but might just need cleaned up. I will check it out for you.....the interior is a yellowish color... an the front an back valances are toast
Thanks for checking on stuff for me, Tyler. I don't really care what color the door panels are if they are in good condition, as I will just dye them anyway. Is the battery tray on the car good?
the battery tray is corroded out really bad
Hey Tyler, could you send me pics of the front door panles and the rear panles, too? Are the armrests in good shape? Thanks for your time.
http://forums.performanceyears.com/g.../icon_cool.gif Did this car have side trim? Did it have cruise control. I need the bellows for the cruise. also, did it have front disc brakes or drum? Power rear antenna? Mine is optioned out so I don't need much.... how is the nose???
Hello I'm and owner of a 69 bonnie convert and it is in need of rear qtrs or at least wheel arch rust repair panels. I can't seem to find any sources for the converteble. Was this fender skirt/weel opening used on any other GM car?
if all you need is the wheel arch area , jc whitney may be your best bet as far as price. i have one that i was going to use on my 70 , but the lower body line is way off. the wheel arch seemed to be o.k.
How is the chrome trim around the doors and trunk lid I have 2 1969 bonneville Broughams
1969 Pontiac Bonnevilles
Do you have a passenger side door side view mirror
I need the endura nose center section. If you have one in good shape.
1969 Pontiac Bonnevilles I have 2
How are the marker lights and the side molding
| All times are GMT -4. The time now is 10:36 AM. |
