-   Electrical Tech (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=424)
-   -   Clock Runs Too Fast (https://forums.maxperformanceinc.com/forums/showthread.php?t=406196)
boboh1 07-04-2003 05:24 PM
Have the original clock in my 67 GTO and had the original clock mechanism serviced. Now when I put it back in(No easy task) and hooked it up it gains 10 minutes per day. Is there a way to fix this without taking it out again? How about an inline resistor? Thanks.
kate`s67gto 07-04-2003 10:42 PM
My clock does that after i lube it. It will slow down after time. Just keep setting it back and eventually it will slow down .
boboh1 07-08-2003 11:17 AM
That's good to know. Thanks.
Cardo 07-11-2003 05:02 AM
I know that 10 minutes a day is excessive, but the shop manual says that these clocks need to be reset (adjust the time) once a week anyway. Mine seems to gain about 30 to 40 minutes a week, and it was a NOS that i put in 5 years ago.
"Not knowing, I hesitate to respond."
jpaitala 08-04-2003 10:20 PM
Mine's the same way also...
It advances 5-10min's a day.
'69 GTO with 455
mikes67lemans 08-06-2003 06:56 PM
dont you wish your time clock at work was like this at the end of every day?
