-   -   Replacing pressed in rocker studs? (https://forums.maxperformanceinc.com/forums/showthread.php?t=408391)
yankeeralph 02-21-2004 05:40 PM
I need to change my pressed in rocker arm studs with screwed studs and I was wondering if this can be accomplished with the heads still on the motor in the car. Also, should the screwed studs be loctited in place. I should have had it done when the heads were off the car but for some reason my machinist did not bring it up. Thanks
Floyd Hand 02-21-2004 06:14 PM
Answer to your questions: No, No, and yes you should of.
yankeeralph 02-21-2004 08:38 PM
Thanks Floyd, I have never done this before but that doesn't mean I won't try. After all, everything we do in life we have never done the first time we do it and look where we are today. (of course we get a lot of bumps along the way).
What are the pitfalls of replacing the studs with the heads still mounted? I was thinking that as long as I keep all the shaving off the head (practice good FME) that I should be OK. There appears to be enough room even with the springs still installed. I am a very good "Handyman" but of course not an expert mechanic.
My best bet would probably be to get a better set of heads anyway. Right now they are 1968 #15 (small valve) and am looking to install some 6X-4 (maybe). A head changout is a lot easier I know, except for that darn bolt by the AC box!! Any suggestions on best course of action to get that bolt torqued properly?
Thanks for your insight!
cioccoj 02-21-2004 09:10 PM
I did mine on the car with no problems. After i got the old ones out, i put a rag around the boss to catch any metal from tapping them and then just tapped the holes. I did loc-tite mine in.
Jody
Goatracer1 02-21-2004 09:10 PM
Dont even consider trying to install screw in studs yourself unless you have a machine shop. If you try hand tapping the holes the studs will not be straight and you will end up with strange vavle train wear.
PMDRACER 02-21-2004 11:37 PM
H-O Racing used to sell a simple aluminum piece for pulling the old studs out, and also used as a guide for tapping the new threads.
Give a shout to Craig Hendrickson on these boards, he may have a few leftover, or know how to get one.
TIGER EFI - Electronic Fuel Injection for the Traditional Pontiac Engine. [email protected]
The point to life isn't necessarilly the decimal.
b-man 02-21-2004 11:46 PM
Here's how I did it......
But I wouldn't want to do it with the heads on the engine. It's difficult enough to do it right on a set of bare heads. http://forums.performanceyears.com/g.../icon_wink.gif
My wife says I never listen to her, at least that's what I think she said.
