-   -   Intake Interchange (https://forums.maxperformanceinc.com/forums/showthread.php?t=410632)
66catalina 04-10-2004 07:06 AM
I have a 66 pontiac intake. When I rebuilt my motor I put 400 heads off of a 72 Pontiac (7J2 heads). I was wondering if the intake would work on this motor. The intake gaskets that came with the head set wont but I cant tell if the intake will not work also.
wheelspin 04-10-2004 09:42 AM
Yes, it will work. I am using a 66 tripower manifold with 71 400 heads (#96).
Les
Goatracer1 04-10-2004 12:09 PM
No,no,no!!!!! The manifold will not work unless you Mickey Mouse The exhaust crossover. You are only asking for leaks later if you do. Get a 1972 manifold (later ones will fit also but have EGR ) or an after market one.
wheelspin 04-10-2004 12:24 PM
My bad, Bob is right, I forgot about the exhaust crossover.
Les
Goatracer1 04-10-2004 02:49 PM
The reason you guys get away using those manifolds is because the design changed in 1972 and he is using 1972 heads.
b-man 04-10-2004 02:52 PM
Pittsburgh 64, keep in mind that only the '64 and earlier crossover ports are round. A freeze plug won't work on the rectangular openings on '65 and later heads.
Here is some info on crossover matching from Jim Hand. http://forums.performanceyears.com/g.../icon_wink.gif
70CONV 06-24-2004 08:47 PM
Learned this the hard way today.I should have checked here first
Shadowjack 06-25-2004 04:27 PM
I use Felpro Performance intake gaskets (#1233) on both my cars to run '72-up heads with early manifolds. No problems ever. But '72 is the unique manifold that fits late heads correctly, and does not have an EGR setup.
