Hello again. My 67 GTO has a 68 #7082268 Rochester quadrajet on it. The 67 Carter quadrajet, that was on it, has on the "coin" #7027262. I threw on the 68 because the accel plunger died in the 67. A friend will sell me his spare kit for a 68, but it is listed to be different than the 67 and I don't want to open his kit if I can't use it. I have a couple broken kits for a 67, but no plunger and apparently the days of buying a plunger seperate, are long gone. Are the 67 and 68 plungers different? What are the differences in the 2 carbs? I never have had a choke, but as I recall, they are different but what about the insides? Also, my 67 has a pressed in float valve seat, the kits all have screw in ones. Where can I get a replacement and what is the correct way of replacing one? Thanks again for any info, Karl.
Short answer - the kits are different.
Long answer. Accelerator pump carb 7027262 is part 7032245 Accelerator pump carb 7027268 is part 7035829 Also needle and seat; and gaskets differ. Remember that the 1967 was the first Pontiac 8 to use the Q-Jet. 1968 was the first year of federal smog emission. The 1967 Q-Jet is a 1 year only with very little interchange with anything else. Items I can think of that interchange - check balls, jets, throttle valves (but not the shafts), and the screws that hold the carb together. Most everything else is different. Jon. Good carburetion is fuelish hot air. |
Thanks for the info Jon. Guess I will have to go buy a kit, but do you know of any replacements for the pressed in seats?
Thanks again, Karl. |
These people sell individual pieces for quadrajets and other carbs. They're a little pricy, but if you only need one part, then it probably makes sense: http://www.quadrajet.com
Thanks for the info on the carb place. I went and punched in the #s for the 68 kit and the 67 kit and they came back with the same rebuild kit #s. The only thing I would actually need is the rubber skirt for the accelerator plunger. The one email showed 2 different #s for the whole plunger, but I am wondering if it is the length of the shaft that's different and not the diameter of the hole? If the holes are the same, then I can use the 68 kit.
Oh well, Thanks again, Karl. |
| All times are GMT -4. The time now is 04:59 PM. |
