-   -   Vacuum Line Help? (https://forums.maxperformanceinc.com/forums/showthread.php?t=425435)
Dean 04-02-2003 11:28 AM
I currently have my brake booster and distributor advance vaccum lines hooked up to the rear base vacuum fitting on my Q-jet carb. Is it ok to hook it up this way or should they be connected elsewhere? Thanks!
David Jones 04-02-2003 01:12 PM
Thats fine. You may find that your car runs better with the advance line hooked to a "ported" source on the carb. Be prepared to adjust the idle some if you try it. Click search and type in ported. Lots of opinions and info available. http://forums.performanceyears.com/g...icon_smile.gif
http://kurtspontiac.homestead.com/DavidJones69GTO.html
[This message was edited by David Jones on April 02, 2003 at 03:22 PM.]
