-   -   68 dash (https://forums.maxperformanceinc.com/forums/showthread.php?t=435057)
dblugly 06-30-2002 11:26 PM
DOES ANYONE HAVE ANY DIFFERENT DASH RESTORATION TIP'S? OR IS THE ORIGINAL PEEL & STICK[WOOD GRAIN] THE ONLY WAY TO GO?
GDK_1968 07-09-2002 02:19 PM
What are you calling "restoration"? If you are referring to the dash pad itself, there is a company that specializes in resurfacing (new foam and het shrunk vinyl). Just Dashes
If you are referring to inserts, then I believe that is the only way to go. If I am not mistaken that is how the appliques were attached at the factory. Check out Ames Performance Engineering online catalog starting with page 21. Inserts galore.
mike nixon 07-11-2002 12:17 AM
p/years also sell the dash inserts.the 68 set is 55.00 p/n is rpi624v. p/y also sells a repro pad . mike
[ July 11, 2002, 12:30 AM: Message edited by: mike nixon ]
