If you have Ram Air 3 manifolds, you know what a pain it is to tighten the one bolt at port 7.
What tool(s) have you found to work the best when working on these manifolds? Personally, I found a cut down 14mm socket works somewhat ok, but if anyone has found a better tool, like a snap-on offset wrench, whatever...let's hear it. |
Socket with the motor jacked up on that side only. Watch your fingers.
| All times are GMT -4. The time now is 02:31 PM. |
